TwinTurbo.NET: Nissan 300ZX forum - If you're having inconsistant engagement
Subject If you're having inconsistant engagement
Posted by Joe@ZSpeedperformance on July 26, 2013 at 1:24 PM
  This message has been viewed 192 times.
In Reply To weird clutch issues posted by hellraz0r1337 on July 23, 2013 at 08:21 PM
Message your adjustment at the master is probably to tight. You need to back it off some, Re bleed and try again to fine tune the adjustment.
Since your adjustment is probably way out of wack, Remove the clevis pin, Adjust until the hole in the pedal and the hole in the clevis line up with the pedal in the up position and re insert pin, Bleed system and go from there.
